Hi Guys:
Did a search looking for the positive and negative battery wire gauge but all results are in refference to voltage, oil, temperature, gas, etc. gauges.
Could someone tell me the battery's positive and negative cable gauge?
Want to install an amplifier and would like to use a battery terminal where I can connect the car's positive wire and the amp wire, same on the negative side.
The cables are (at least on a 2002) metric 35.0 , which is the cross sectional area in mm^2.
The closest AWG size is #1, which is a bit larger.
Bill
