I have a 2001 C4 CAB w/Tip that has the PSM and ABS lights that stay ON. The PSM switch doesn't do anything. Problem started after a weak battery was charged. Everything else seems to work fine and car appears to run OK. Other posts point to MAF but this seems like a strange coincedance that it started after I charged the battery. Could it be as simple as a blown fuse ? Some posts indicate brake light could be it. Let me know if you know of other things to try.
Edited by pstarenas
