Trying to find a tach lead to hook up a shift light. Using a Autometer, Raptor light that has three leads, 12 volt, ground and a tach source. Can't seem to find out where to pick up the lead. Before I go ahead and remove the instrument cluster does any one have a suggestion on where to pick up the tach lead?
On a MY05 Turbo S the easiest place to get it is the Violet/Green wire that goes to the OBD II (diagnostic plug).
Loren,
Is this the same for 01 TT?
Loren,
Yes, on a MY01 internally it goes to different places but that is the same signal.
Thank you for the info. As you said there is a violet and green wire in the ODB II harness.
Can I get my 12 volt from pin 16 and ground from pin 4 of the ODB II plug or would it be better to use what I think is the telephone plug that I found behind the air controls? If you would use the telephone plug can you identify the 12 volt and ground wires in that plug?
I would use the 12 volts from the telephone plug - the OBD II needs +12 volts for some programming functions.
The telephone connector has been covered here many many times - please do a search.
Got it "THANK A BUNCH"
  • 11 months later...
searching and found this thread...
how about for a '03 4S? since I'll be removing the instrument cluster to mount a shift light can I pick up the signal from the back of the tach? and what color wire would that be? Is there also a good place to tap into an 'ignition on' power source in that same area?
