Does anyone have installation instructions for GT3 sway bars and drop links? I just got mine, and haven't looked at the car yet. It may be simple, but is there anything I need to know before I start taking off the current bars and links.
I have a ROW M030 on my 99 C2.
Thanks for the help in advance.
Adam
Adam
It’s pretty easy. To change out the front you have to remove a front panel held on with clips and bolts, move two cross braces out of the way by disconnecting one end and loosening the other and then you have a steel brackets on each side that you need to get out of the way by removing the two end bolts and loosening the middle and pivoting the pieces so you can drop the old sway bar out once you unbolt the drop links and the mounting brackets that also hold the bushings. The rear is even easier since there are no panels in the way just unbolt it from the drop links and unbolt the mounting brackets.
Check out the link below it shows the drop links that has to be removed to replace the springs and shocks and has some torque specs that you will need.
http://www.renntech.org/forums/index.php?showtopic=7073
I hope this helps.
Lee
