Can anyone tell me what size (width) wheels and tyres I can put on my 2001 996c2 without the use of spacers.
I was thinking about getting the following:-
Front :8 x 18, 225/40 ZR 18
Rear :10 x 18, 265/35 ZR 18
Edited by andy102
The tire sizes you mentioned are the OE tire sizes for the 18" factory rims. Should work fine..
Just make sure they are Porsche wheels. If not, you have to take into account different wheel offsets from other manufacturers. Also the bolt pattern has to match the your car, 5 x 130 mm pattern or the bolt holes won't lign up.
You can put 18" wheels with 285 tyres on the back and they are fine.
If you go to PWS Wheels in Blackpool UK (google) they are selling 19" wheels that they say will fit the C2. Personally I would have thought the ride quality was poor at that level.
The other factor is tyre pressure. Porsche recommend 36 and 44. I find this way too high and the same guy at PWS reckons 30 all round is far better.
