I have a low mileage Boxster S, and as of today, the ignition won't turn off. The switch returns to the off position, but the lights and radio stay on. The key is hard to get back in, which makes me think my switch has given up the ghost. Is there an easy fix, or am i in for a new switch, and if so, is that a dealer replacement, or something a two star mechanic (out of five) like myself can do?
Thanks in advance.
yes, sounds like you need a new ignition switch. the part is $20 at Audi dealers. just make sure you get the right one.
and yes, you don't need much mechanical expertise to change it out. all you need is a small screwdriver and contortionist skills. ;)
here's the DIY: http://www.renntech.org/forums/index.php?showtopic=493
you probably just need to replace the switch behind the lock tumbler, not the tumbler itself.
Thanks a ton. I will give it a shot!
