seatback adjustment blows fuse
Hey all,
I have had a problem with my driver's side seatback not moving. It instead has blown a fuse 4 times.
Here are the symptoms:
1. I attempt to move the seatback, it moves a little and then stops...regardless of direction
2. Seat no longer moves
3. Notice fuse is blown.
4. Replace Fuse
5. seatback moves a little then stops.
6. fuse is blown
See the pattern?
I'm not sure what the cause is. any thoughts?
2000 Boxster, 2.7L, no memory seats, no heated seats, 3rd party alarm system.
Will
<_<
Well, if you have an ohm meter you can take the seat out (disconnect the electrical connectors) and test each wire for a short.
It is either a shorted wire or a bad motor.
Thanks Loren! your help is always appreciated!!!!! :clapping:
