I have a RoW 1998 3.4 996 coupe - the brake lights have stopped working
How are the lights triggered on the 996 - I cannot find either a pedal switch or a pressure switch. I am guessing it's a faulty switch , or relay ?
thanks
996Toulouse
I had the same problem with a 2001 996 C4. The PSM and ABS fault lights also came on. It turned out to be the Brake light switch which is in the area of the Brake Pedal and is easily replaced.
Interesting - there is no switch in the pedal area on my car.
Are you sure?
If your Carrera has Cruise Control then you would have two switches on the brake pedal arm.
Are you sure?
I'm not 100% sure as everyone is telling me there should be a switch there ! But I have had a pretty good look without dismantling the dash and I cannot see one. The car does not have cruise control and I can see the location for that switch and the unused harness to connect. Anyone have a picture of where it is located ?
Are you sure?
If you can see where it should be mounted and the harness, then it sounds like the switch is missing just replace switch and go from there.
Edited by Mother
