Hey guys,
I wanted to remove the front passenger seat in my 2006 997 Carrera, but didn't know how to go about doing this. I was wondering if anyone can help me out (I plan on replacing the seat immediately afterwards but I wanted to remove it for a while).
Thanks in advance!
If I remeber right, You remove the plastic clips from
the front of the seat rails with a small screwdriver. Then torx out the bolts. Then
slide the seat forward and undo the two torx's on the rear rails.
Last you disconnect a wire that is under the seat. The hard
part is disconnenting the wire. Then remove the seat. The
driver's side is easier then the passenger side for disconnecting
the wire.
Paul
