I have 1999 996 C2 and the lower cover for the mirror on the driver side has come loose. The far side is not attached but the side closes to the door is still attached. I have a replacement part on order but I’m not sure how this part attaches and I don’t want to chance breaking something else. I would surely appreciate some help.
Lee
Carefully pull the mirror glass out of the metal clips. Disconnect the electrical plug connection.
Press lugs (arrows) of the lower cover and remove it.
Install is the reverse.
Thanks Loren, you da man. :notworthy:
  • 4 weeks later...
Lee
Lee,
I have the same problem with my 99 996 C2 drivers side mirror. Do you happen to remember the part # or where I could locate it?
Many thanks from a fellow brother!
Tim S :) :)
