Well, trying to fix a side mirror that broke on my 99 cab. In the process, the following happened:
Since I did not have the car keys at the time (wife had them) I decided to lift the cab top manually, using the manual way as shown in the car's manual. That worked fine. But then, when trying to bring the hood back again using the switch... it did not work. I forgot to mention that in between, the battery was disconnected to mess with the mirror....
Any suggestions for this novice DIY fellow? :cursing:
Edited by CabC2
