what's the two-wire plug connecting the soft top frame to the car? it looks like it connects to a top-related microswitch on the top frame near the drivers left shoulder. i operated the top without that connected and now have a problem. :( is it a "stop, we're done...don't go any futher-microswitch???"
i had the darn top all put back together after a tiny repair...everything was looking good. top operated down perfectly. top went up perfectly....UNTIL.... a loud pop the second after the light went out (top operation complete). the top is now up and everything looks great, but trying to put the top down and i get a dramatic "pop" every second or so.
ideas????
thanks
Hi Doug,
That is a microswitch that tells the motor to stop. I just went through this repair. See the other article under top repairs, started by me, poobha. Mark and Toolpants offer very good advice. You will have to disconnect the push bar and thrust rods from the transmission drive levers, retime your transmissions and put it together. All your info is in the top Issues and solutions. Read all recent post as they are very helpful in getting this corrected.
You have essentially run the gears off the transmissions because the top wasn't registering itself in up position.
Good luck.
Marco
thank you marco (and mark and jeff)...and crap, crap, crap!!!
i had quickly reviewed everything in this forum the other day but read right over your perfectly applicable discussion because i didn't have this problem at the time. i can't believe i was 30 seconds from being done with my little repair (just connecting the stupid connector before testing the top), but now i've got an opportunity to learn more than i wanted to know about synchronizing the top.
Hey Doug,
Usually education cost money, but in this repair it just a few skinned knuckles. Believe me I shared your frustration when my top did the same thing.
Marco
