Hello, I am trying to diagnose a fault code with my ABS (P4200) on a 1999 Porsche 911 C2. Is there an online listed of these fault codes that I could review? I found the one for engine codes but nothing for ABS modules... Thanks,
David
The workshop manual says:
Front right
speed sensor,
open circuit/
short to ground/
short to B+
DTC 4200
General procedure as for test point 6/diagnostic trouble code 4205.
- Speed sensor signal: Check with the Porsche System Tester 2
via the Actual values menu (call up front right wheel speed).
- Internal resistance/continuity between PIN4 and PIN5 on the
control module connector.
Thanks Richard!! I installed a new steering rack and when I had the front suspension apart I guess I unplugged one of the connectors by mistake. Thanks for letting me know.
David
Front right
speed sensor,
open circuit/
short to ground/
short to B+
DTC 4200
