Hi guys,
Having recently just fitted a Smart Top to my 2001 C4 the roof now opens and closes followed by a protracted pause and then drops down / slams shut at an alarming rate. I've removed the Smart top and the problem remains.
Fitment of the Smarttop may be a red herring, but it's a bit coincidental. Any help / suggestions would be appreciated.
Eric
Sounds like you need to get the roof adjusted and calibrated. The steadler does this, but make sure the SmartTop is removed when you take it. The SmartTop did not do this.
At the same time, check the hydraulic oil level!!
