Hi
Does anyone know what the is the position of the crank sensor relative to engine top dead centre. It should always be before TDC. It can be anywhere in 360 degrees of crank rotation.
I need this position to setup an aftermarket ignition system.
Also does anyone know if its a Hall Effect or Magnetic / VR type sensor?
Thanks for any information.
Marcus
The crankshaft pulse generator position reads the gap (two missing teeth) in the flywheel ring gear. The gap produced by 2 missing teeth serves as the reference mark and lies 84° before the TDC of the 1st and 4th cylinder.
