Excellent install. I find myself coming back to this thread all the time. I have siilar questions as to the wiring methods used as well as the power to the amp.
To clarify you used the 4" QSC's on the dash, the 8" Kickers in the doors as mids and the 3.5" Kappas in the back as rear fill?
Do you have any pics of this lexan enclosure? I just can't picture it. How big is the enclosure? I am thinking of using the same Kickers in the doors as well. However I might go the route of using the doors as the enclosures. How would you go about sealing the door completly though?
::BUMP::
"Do you have any pics of this lexan enclosure? "
- or some instructional advice? I have two ssm8's sitting here and trying to figure out how to mount them.
guys,
when you move the climate control down do you need wire extension? or can you make the factory wires stretch enough?
I have a 99 Box Tip non S.
Thanks, Kevin
::BUMP::
