I'm planning on installing a laser jammer (probably Blinder M20) for the front only. Since I have a laser detector in my Escort, I don't need to hear the alerts from the jammer, I just need it to jam, so I won't have to bring any wires into the passenger compartment. This should make the install a fair amount easier. What I need however is a source of power under the bonnet that is switched with the ignition. Can anyone help me locate one?
I couldn't find any on a 987, ended up bringing one from the fuse box through to the front.
if you have a 997, you can use the CD player wiring harness located on the passenger side, under the carpet (where the CD player would go or is mounted) Most all of the Dennison Ipod users have tapped into the switched power wire and ground. 12V switched = red/green. See pic
Thanks Bob, that's exactly what I was looking for!
Not sure that is switched with ignition, Dension unit requires unswitched for the MOST connection!!
