I just found out that I need to replace the dist. cap belt on my 964 and was wondering if anyone has done this procedure and could give me any tips or insight for my after holiday belt replacement.
  • 11 months later...
Just bought a 1991 964 with 47,000 miles. Distributor belt is broken. Have you found two timing notches on your crank pully. One is TDC, what is the other one?
