Hello all,
just joined the forum, what a great source of information.
I bought a 2003 Boxster last week and I love this car.
There was no code card with the radio, could somebody help me with the code?
Model CDR 23 Model Number BE6612
Serial Number 25020179
Another question, would a regular Becker Traffic Pro fit as a plug and play or are there
problems to expect with the BUS System.
I have no BOSE sytem, but I do have an amp in the front trunk.
Edited by 916sp
:welcome:
CDR-23 does not need a code - it communicates with the DME to get permission to operate.
First, it maybe tough to find a Becker Traffic Pro.
If you use it on your car it will not use the MOST system - it would need to be hardwired.
:welcome:
Thanks a lot, Loren :thumbup: !
So to hardwire means that none of the existing plugs can be used?
You will have to look at the back of your CDR-23 - there should be "wired" plugs. What you can not use is the MOST fiber optic connector.
http://www.renntech.org/forums/index.php?s...;hl=traffic+pro
Trying to use a non CDR23 radio in a 2003-2004 is a pain due to MOST. The CDR23 communicates to the amp (and cd changer if you have that) via fiber optics. The CDR23 does not have a conventional 12 volts from the ignition when it is turned on.
KarlS put in traffic pro but he has a GT3 that does not have the amp, and he ran into problems. But I think he finally got it to work.
So if you want to use the traffic pro we use for 1997-2002 in a 2003-2004 then you will run into problems and it is not plug and play.
Thanks a lot guys, I think I go with a tom tom or something alike and try to intall it nicely in the center console.
