I honestly cant remember if it was there before or not, but when listening to the left side of the car when idle you can very slightly but clearly hear a consistant ticking noise, its better heard when your listening near the air intake.
If best described it sounds like a metal tapping together, cam tapping a valve sort of sound
Its not affecting performance and you cant hear it under acceleration
It's an 01' S, 29,500km
I have only picked up on it recently and im trying to figure out if im going crazy or if it was there before
What could it be
Cheers
It is normal to hear some tapping sounds. Especially on cold start-ups. This noise can be pronounced if you are not using the correct oil and viscosity too.
Phew luckily
Yep its due for an oil change real soon, I should of done it allready but havent had the time
Thx Fellas :)
Edited by 911-996
