What is the most updated seat belt recepticle part number for 1997 boxster?
Im pulling a code 41(driverside seat belt unplugged) error, tried cleaning and the airbag light stayed off for 3 hours then came back. Need some guidence with this issue.
What causes the seat belt to fail like this? is it the connections at the blue plastic end or internally within the housing of the recepticle?
Corrosion.
Could be either contact point. The newer ones have gold (plated) contacts on both.
The grounds under the seat should be checked too (per the TSB).
Does the TSB say that the grounds have to be changed, relocated, cleaned or tightened?
Yes, but they say change both buckles and they are making double sure it doesn't happen again by re-soldering the grounds.
One of the benefits of being a contributing member is you get to read the whole TSB (all the TSBs) - with all the details ;)
