I am still deciding on the best way of lowering the car. It looks like it's gonna cost me $1800 for the part and $1300 for the labor if I get the European OEM Suspension Kit, but only $900 if I go with H&R Spring.
My understanding is that they both just lower the car. What would recommend if I want to just lower the car? BTW, does anybody have the part # for European OEM Suspension Kit. My dealership gave following part # but not sure if they are correct.
997-343-041-12 AS VIBR
997-343-531-43-504 COIL SP
997-343-701-07 STABILI
996-343-792-17 RUBBER
997-333-701-15 STABILI
996-333-792-25 STABILI
997-333-051-09 AS VIBR
997-333-531-49-504 COIL SP
997-333-061-01 SUPPORT
Cheers,
Heejin in Seattle
Edited by Heejin
  • 4 weeks later...
Cheers,
Heejin in Seattle
I am planning on doing the same thing. that is the only way to go. where did you get the part numbers from they are not available in the us
ronnie
  PAULSPEED said:
Just be careful because my friend blew out his shocks
by going with the H&R springs.
Paul
Paul: How many miles was it before the OEM shocks blew out after H&R installation? Did he have 18, 19, or 20 inch wheels?
Thanks.
Edited by paragongja
I would guess he had about 18,000 miles. I
would get bilstein PSS9 coil overs if
you want to lower your car. I think
the pasm system dampners need to be balanced
with the coils. Installing the european suspension
with out installing the european dampners would
be the same as just installing the H&R springs. This
is just my thoughts on this issue.
Paul
  PAULSPEED said:
Paul
we are not talking about the just replacing the euro springs, its the whole euro 20 mm sport suspension , which included, new sway bars, new spring , struts, bushings.
  cgng30 said:
  PAULSPEED said:
Paul
Sounds like you have it covered. Are the struts made for PASM or
will you have to abandon the computer strut stifness? I thought
that the european cars did not have PASM.
Paul
  PAULSPEED said:
  cgng30 said:
  PAULSPEED said:
Paul
Paul
They do, and the car automatically is lowered an additional 10mm upon engagement of the "sport mode" for the PASM selection, US cars don't get the auto lowering.
Dave
Edited by Dave07997S
Nope bad luck, the car comes 10mm lower it doesn't lower itself when you press the button
In the UK there are 3 different suspension setups, standard, PASM (-10mm) and sport(non PASM -20mm)
Cheers,
Heejin in Seattle
Heejin
did you figyre out the parts , and did you order them just curious.
Cheers,
Heejin in Seattle
so after about a year i have upgraded the euro suspension on my car in my garage. i assembled the whole unit instead of reusing some of the parts that are common between stick and 20 mm. it was a easier swap , and I have the stock suspension left over including the swaybars , bushings etc. so far its looking good, i have to get it aligned. it is understeering more then before, i am wondering if that is normal without alignment.
Heejin
