PSM and non-N rated tires paranoia
Assuming the Boxsters dynamics programmed in the PSM software were tested and optimized using N-rated tires, would it be true to conclude that PSM would be less effective if I used tires that didn't have the Porsche N-rating (e.g. Yokohama AVS)?
David
