Assuming the Boxsters dynamics programmed in the PSM software were tested and optimized using N-rated tires, would it be true to conclude that PSM would be less effective if I used tires that didn't have the Porsche N-rating (e.g. Yokohama AVS)?
David
N-rating does not matter with PSM - you should be concerned with rolling diameter. Stay within 2% of the factory spec and you will be fine.
N rating is who Porsche is currently in bed with. Get any tire that is rated highly. The best tires out there are not N rated.
