I just bought a boxster and I can't open the roof. what is the correct procedure?
i did 1. pull the PKB 2. unlock the covertible top 3. push the switch
what is wrong?
Sounds ok to me (assuming you've got the key in the ignition to give it power and the parking brake sensor is ok?!). When you pulled the roof release handle did the windows drop a few mm? If not, could be a dodgy microswitch on the release latch. Failing that, perhaps the relay or a fuse?
The hread titled "winshield microswitch" is probably worth a look.
Edited by joshm
Thanks for your help. I found the problem. It may caused by PKB switch. Somtimes, when I pull PKB, there is no brake caution show on the combination meter. If no brake caution, the roff wll not work. So, how can i fix the switch?
Replace it. The part costs about $5.
can i have a part no.? can i do it myself?
Do the 18 pin hack = pull the top relay and bend over pin 18 and replace...problem solved!
(relay is the biggest above the fuse panel)
