I just got a Mityvac to change engine oil and bleed brakes. Can it be used to change transmission oil or FWD differential oil? Does sucking all the oil out of the fill hole make the job any easier or is it six of that and half dozen of the other?
I wouldn't use a vacuum pump to change the oil or brake fluid.
1.Draining the oil is the proper method - when its warm and drain for at least 20mins - since it will help remove any sediment and most of the contaminents. Vacuuming with a Mityvac won't.
2. Porsche recommends pressure bleeding the brake system to refresh the fluid. The Motive power bleeder is the one most frequently recommended.
If you use a Mityvac , you can't tell if all the air is out of the system since air can get introduced at the bleeder valve into the bleeder hose - and possibly enter the brake system too.
You could also use the 2 person manual system for bleeding the brakes.
