Is is easy to remove this switch on a 987?
I would like to meter the connections to see which one is on when I turn on the headlights.
thanks
Push the switch in and then turn it to the left. Itll come right out.
I tried to remove the switch, didn't work for me, maybe it's different for the 987?
PTEC is correct.
I'll try this again,
I was pushing on the outer trim ring not the rotary knob and I was turning it to the left...
