Has anyone tried to install a 2 generation (really small) 1GB I Pod Shuffle to a PCM2 (2003 TT)? Thanks Alex
I'm not sure why size matters...You have MOST so you will need an aftermarket solution for it to be seen in the fiber optic ring. I have the Dension Gateway 500 and have the iPod hooked up...works great!
Size matters in regards to the new Shuffle, since it only has a earjack to USB cable to charge and load music. No screen. Can you see video on the PCM2 from your Ipod?
PS Denison, no longer does business in the US according to a website.
I mean size does not matter for the connection...You can get the Dension box from Eric @ bumperplugs.com. Yes you can see tracks on the screen if you have nav...don't know about others. Check out this link for all you want to know:
Dension
