Hey guys, there's a bunch of conflicting information regarding the instal of Sirius. The two threads here suggest further programming is not necessary, however, both dealers I have contacted report that further programming is necessary for the unit to function.
Before I order the parts, can someone please confirm?
Many thanks. Jamie.
This is tough to answer with 100% certainty. There are two programming operations that might need to be done. First is you need to have the right PCM software, which is Model level B. There are instructions floating around on how to figure out if you've got A or B. Assuming you have a 997TT (based upon the forum you posted in) then you have PCM Model level B software. Earlier 997s had to be updated from A to B and most dealerships didnt just have the update cds just lying around. Secondly, as the Satellite control unit plugs into the MOST ring, it is possible that the PCM will need to be coded with the changes you've made in the MOST ring order, ie, added a control unit. However, I have done CD changer installs where it will play after plugging it in without making any coding changes, it seems to be a crap shoot. The only way to find out is install the kit and fire it up and see if you get anything. If not, then you're in for a trip to the dealer.
