I've had an annoying rattle for about a yr now, I think it's one of the cats. When I trap it with a mallet one sounds dull, the other hollow. Loren, any advice?
TIA
CH
Well, I guess you could always take the cat off and shake it to be sure.
Unless the break is near (where it could be welded) the end it likely means a new ($$$) cat.
TIA
CH
I banged on it with a rubber mallet, the passenger side(the dull one) has a clear rattle. I believe the emissions system has a 100k warranty, besides I replaced them about 1.5 yrs ago under warranty, so I should be covered.
I just had my driver side cat replaced by the dealer under warranty. When I tapped it with a rubber mallet it sounds like there are loose marbles in there. Is that what you got?
My car is only at 20K miles, so warranty is still in effect (got a certfied P-car), so can't tell you costs.
