How much play is allowable in a stock shifter setup, Currently i have nearly a half inch of play (side to side) in my shifter. Is that too much play?
Yes.
Unfortunately, not much you can do about it. The side-to-side pivot mechanism uses plastic for the pivot joints. It wears out.
A friend and I are working on a solution to repair the older, worn-out shifters, as well as tighten the action on newer cars. Stay tuned.
Yes.
Neat! ok keep me posted please
