guys,
Do ny of you know where the rev dial control signal comes in?? I thought it was pin 14 on the white cluster plug (TN signal), but this shows no sign of voltage variation during reving.................is this because it is a PWM signal??
If anyone can help, please please let me know.
Many thanks
Russ
guys,
Many thanks
Russ
Year of car is ???
If you can't find the speed signal on the cluster presumably you could always tap into the speed signal on the CDR220 radio connector (which is used to control the speed dependent volume function).
The signal is on Pin 1 of Connector A (the lowest connector)
Tach signal is the TN signal (Vi/Gn, on Porsches it is always the Vi/Gn wire), pin 15 on the white plug on a 2000 I think.
Todd
Edited by tholyoak
I think if you want that sort of detailed info, you will have to hook it up to an oscilloscope. The factory manual has the sinusoidal trace for the ref sensor at idle but that is about it.
Todd
