I'm about to change brakes (pads, rotors, fluid flush) on my 2000 2.7L w/ ~40K mi, and have been searching archives for a one-stop source for commonly needed torque specs. Couldn't find it. Is there one?
I've gathered the following specs re brakes: big caliper bolts @ 63 ft-lb; lug bolts @ 96 ft-lb, rotor hold-down screw @ 7 ft-lb.
What about brake line connections and brackets? Also, this probably is a good time to do spark plugs, right?
best
