2000 Boxster S
In a nutshell here's the problem: Sporadically ( about twice a week) when I get into the car, engage the emergency brake, push in the clutch (6 speed manual), and turn the key clockwise. But, it might not start right off the bat because I'm in a hurry and didn't hold the start position long enough. So, I turn the key back rapidly counter clockwise and some times go too far into the accessory position. If that happens, it takes me a good five to ten minutes of playing around to get it turned clockwise into the normal OFF position and onward to finally start it. Key looks good, led light and locking/unlock functions are OK and the car has only 17,000 miles on it. This is starting to drive me nuts. Is there a solution? Thanks.
Probably the ignition switch is binding the cylinder. It's a cheap part, but a little tricky to replace. If you take it to the dealer, they'll want to replace the key cylinder too, which is kinda expensive.
