Please forgive a dumb question but I need to put my mind at ease.
C2S 2007 build Carrera Sport wheels with coloured centre crest.
I have a slow, front left-side, puncture which I will be getting fixed later this week. While searching on another forum for tyre depots that can be relied on not to damage rims I came across a comment that implied that removal of the wheel centre caps was the most difficult part of the task.
I will most likely buy my tyre on-line, remove the wheel and cap myself and take to a local depot to have it fitted.
Is there a recommended procedure for removing the wheel centre cap that will minimise the risk of damage?
Allan
(Also posted in Boxster forum)
If you want to remove the center caps (with the wheel on the car )
take a heavy piece of wire( coat hook ) and spread the ends apart
approx. the width of the two holes in the cap.
Then with a pair of pliers bend each end ~ 1/4 inch long , 90 degrees.
Insert the ends into the holes and pull the cap off .
(or you can buy the "special" tool from Porsche for about a weeks salary . lol )
Nick, Jean, thanks for your response. The wheel will be off the car so it looks as though this ought to be a very simple task. It was just that I read of someone having difficulty removing the cap, even with the wheel off, that made me think this might not be so straightforward. I've only had the car a few months, it's my first Porsche, and not had any need to remove a wheel until now.
