Door Panel Removal
you won't need to remove everything. just the plastic piece over the door handle and the C-clip on the piece that you're painting.
when removing the plastic piece over the door handle, be very careful. it has plastic pins that can break very easily. but if you DO break them (like i did) they still fit securely and are much easier to remove next time. ;)
Edited by Chris_in_NH
