Hi - trying to locate the part no for the trim piece that covers the roll-bars on my 199 C4 Cab. At the moment , the fabric is pretty scratched up - it also seems to be a bit loose which means that the wind deflector rattles pretty loudly as the clip that kidn fo sits above the rear seat back it wobbling around a lot. Have searched for a solution - perhaps it just needs refitting, but as its pretty scratched, might be time to replace
thnaks Loren - this isnt my car (camera is broken!!) but this is the trim piece (number 1 on diagram) I'm looking for. Whilst fitting my nav system I think I have broken some retaining clips as it moves about. As the wind-deflector slots into a gap between this piece and the rear seats that too is rattling and driving me nuts. Not sure how the previous owner managed to make such a mess of it though - I need it in black. was hoping to find a part number and if it is too expensive just find out how it is assembled/removed so I can try and at leats fix the rattling
thanks v much
Alex
Edited by alexbartman
thnaks Loren - any idea how to remove and refit it.....guess its probably a case of prying it off and then re-seating it?? Be great if you could confirm though!
thanks
Alex
