Hi there
I have been reading various diagnostic threads about a ticking sound in my 1999 C4 - before I invest time and money with a specialist - I thought I'd try and see if it was the EGR valve - as has been pointed out in many threads. Problem is, I dont know where to find the EGR valve to disconnect it - and if it is that, is it a simple case of replacing the EGR - is this an expensive part and is it DIYable??
thx
Alex
EGR Valve is right above the alternator. The valve has an electrical connection to it and it also has a soft rubber hose that conects to the throttle body.
If you need to see if the ticking is coming from the EGR valve have the car running and disconnect the electrical connection.
It is normal when you here the ticking from the EGR valve. The EGR does this and does not need to be replaced
