Hi there
Does nayone know of an ignition-switched power supply I can take a feed from in the engine bay?? Id like to hook up my reversing camera to an ignition switched live feed instead of the reversing light....its a real gmmick, but Id like to use the camera without having to go into reverse!!
thanks for advice
Alex
The car phone would be the easiest location, already inside the cabin, passenger footwell in the center console. Do a search by Valentine One for the radar detector hardwiring instructions, someone did a good job of documenting with pictures which is the power feed and ground.
thnaks for that - but I wanted to avoid going into the cabin - its a lot of work and not really worth it - if I can keep it inside the engine bay - I wont have to remove any of the interior trim which although not difficult, is fairly time consuming!!
Not sure about the engine bay, sorry. Where would you have the display screen? I assumed (incorrectly perhaps) that the display in the cabin would be power source to the camera in the rear.
The display screen is my new Pioneer Double Din Head Unit - and the only feed is a video RCA cable into the back of that. Teh camera on the rear bumper needs its own power...
no - think Im onto a loser with this one!! The only solution is to run a feed from the stereo through the cabin and into the engine bay - not much fun - dont think I can actually face the heartache of removing everything again - once was enough to be honest!
