did not follow the instructions 100%, instead of taking out the drain plug, wait for the oil to drain, put the drain plug back and then replacing the oil filter this is what I did:
removed the drain plug and the filter, waited for the oil to drain ( aprox. 2 hrs.), put the drain plug back and then replaced the oil filter, the engine was cold. Would that have adverse consequences, air in the oil ducts, etc.? Also, put 9 qts of mobile 1, the dip stick and the dash gauge shows under the low level line. Turned the engine on for about 3 to 4 min but no change on either measuring method. Any suggestions?
