Got a questions about some of the tools needed for repairs and where they are found.
Oil Drain Plug
Transmission Drain Plug
Transmission Fill Plug
The oil drain pug is a standard allen socket available at an auto parts store.
My transmission fill and drain bolts were also allens.
It's possible you may need a Hazet 16mm triple-square tamper-proof (hole in the center) socket to remove the trans drain bolt. If that's the case, you might try http://www.zdmak.com or http://www.samstagsales.com.
I've also seen the socket on Ebay.
  • 4 weeks later...
LAPTOP CRASHED ---- Sorry for the non-reply after posting.
Thanks for the info. I do have the "tamper-resistant" trans plug. I'll have to do a search.
Anyone know of a good way to remove the bolts for the spark plug coil-overs? I was able to remove one, but the other 5 I could not get a good tool in there. Thoughts?
