I see from looking at the PET that the oil filler tube is divided into three parts. Since the entire pipe is covered in oil residue, I can't tell exactly which segment is leaking. Is it usually the middle segments, because of the shift cables leaning against it? Or would it be the elbow on the engine, since the middle segment is flexible? Is this thing a nightmare to change?
I've also got an obvious leak from the AOS where it plugs into the block (not the bellows). Neither is more than seepage, but it's annoying and I can faintly smell oil from the passenger side engine vent after driving.
