Hi Loren and Co.,
I've searched unsucessfully for the last couple of days for this one. I have seen the recs on removing these with a soldering gun :( . I am willing to take the dash apart to install these 3 strips correctly. Does anyone have pics or instructions on what needs to be done? any help would be greatly appreciated.
thanks,
geoff :D
thanks poursha for the great pics. However, I am still a little worried about the soldering gun technique. anyone else have pics or ideas?
thanks
geoff
:oops: thanks poursha for the great pics. However, I am still a little worried about the soldering gun technique. anyone else have pics or ideas?
thanks
geoff :oops:
Edited by gabf1
Behind the stalks is a black trim plate, just below the instrument cluster. If that plate is removed then you can get to the back of the 2 short mouldings by reaching behind the dash and using a T10 bit. There are 2 screws in each moulding.
But to get the trim plate off you have to remove the steering wheel and the 2 plastic covers for the steering column.
If your car had a glove box then you would remove the box and then you can reach behind the dash to get to the screws for the long moulding. No glove box - then you have to do it the brutal way.
