[check that all the spark plugs are properly tighten and not broken. had the same happed to me and I was chasing the squeak for a month. So took to dealer , ends up being 2 loose and one broken sparkplug. Replaced and on the road...
  • 11 years later...
I know this is an old post, but it helped me to identify loose spark plugs as the culprit (I love a free if fiddly repair!).
Having read this, a couple of things that helped point me at that being the likely cause:
  • Stationary in neutral, the chirp/squeak was proportional to engine speed and discontinuous (I would expect a loose/slipping belt to be continuous).
  • Coasting slowly downhill, in gear, lifting off the throttle at something like 1500-2000rpm, the chirp stopped (this is probably related to the system cutting the spark on the overrun when it wasn't required). Touch the throttle lightly and the chirp came back. This was the most convincing thing for me before I did the job of tightening spark plugs and might help others.
  • Only did it on cold start - presumably once everything is warm then the gap seals under expansion.
