  koya1893 said:
Has anyone experience Victor wheels like the one's in the link below.
http://www.ddswholesale.com/catalog/Victor...eels/Album2.htm I decided not to track my Boxter S so I am going to replace stock wheel with something like these with Nitto's tires. Any suggestion as what size to have on 19" wheels. The car is going to be a daily driver.
Ben
Seems from lots of posts here and at other boards, 19" wheels don't seem to be very popular on Boxsters. Seems the 19's effect everything from ride comfort, rigidity and, besides the tires are alot more expensive.
Not only that, they are friggin heavy. Unsprung weight is everything, go and add huge amounts of weight to your wheel and tire setup (19" wow) and it will be like somebody just sucked 20hp out of your car.
Even if the weight is the same as your 17" the 19" are larger and thus pushing the weight out farther away from the center of the wheel taking more inertia to turn. Even at the same weight the car will be slower.
From a performance standpoint fit the smallest wheel you can (within reason) but one also large enough for visual appeal. On a boxster that magical number seems to be around 17" as you really can't readily get a 16" tire thats 265 in the rear. When you can find them they are super expensive. If you have to go larger than 17" then go to an 18" which even at that will slow the car down.
Edited by 986Jim
  jmatta said:
Those would make your Boxster look like an Escalade!
actually my car looks great with 19" black mesh. and yes its still a PORSche. however the ride is stiff, its a bit of trade off......looks vs performance. .....make sure to get hub center rings to reduce vibration.
My 03 has the Porsche M411 optional 18" wheels, but Porsche offered that option with specific light weight alloy Carrera wheels to offset the issues that Jim stated in his post.
They look kinda nice. I'd prefer a symmetrical design... the spokes look asymmetrical... so they'll look like they're going one way on one side of the car, and the other on the opposite side. I have the 'twists' on my car, and they are my least favorite p-car wheel. Someday I'll remedy that.
I echo what people say here. Bigger wheels will affect the power you can get to the ground, and how fast you can get it there. They will affect ride quality, and will result in more expense for tires.
I'm happy with my 18" wheels, and if I replace them with the ones I want, I'll probably stick with the same sizes.
Jim, no logic in your assertion, the wheel diameter with tyre is the same no matter what the rim size as the aspect ratio of the tyre reduces, this also affects speedometer readings.
Weight difference would be so negligable no one could measure a difference, of course you could also claim driving at night the car is slower as there is a greater load on the alternator powering the lights, or having just had a meal the return journey takes longer - sure there are differences but not worthwhile differences, I would also guess the extra alloy to make a 19 inch rim in weight is less than the reduced tyre aspect ratio, well perhaps a few gramms.
http://www.1010tires.com/TireSizeCalculato...p?action=submit
Too bad they don't give the weights for the wheel combo's.
Anyway i am going to go with 17" being the lightest of all. I can't remember off the top of my head the equation for calculating the weight of something spinning but i am sure it is more then negligable. Anyway remember back to when Porsche had the brake calipers on the front of the rotor? I am talking about the front brake systems. Then they moved them behind the rotor. Why? Cause having that extra weight behind brings the balance of the car closer to the center. Less weight in front of the front wheels the better and opposite for the rear.
The "Negligable" comment refers to the measurement of performance, the mass as a whole has the same diameter no matter whether you have a 17" rim or a 19", the tyre weight for the smaller rim will be greater than the tyre for the 19, put the two together and the difference is negligable - and couldnt be measured in straightforward performance.
Anyway if performance is everything then only slim people shoud have a Porsche, spare wheel can go and have a can of inflater/sealer, remove the passenger seat to prevent extra weight getting in the car and saving the weight of the seat and remove the roof as you can get a hard top (alluminium) for the wet days, we could go on but i just find people become so focused in the minutia that reality gets lost (Like audio boffins who have their speakers on little metal cones,, and driven using low loss cable) the world has gone mad.
Drive and enjoy the car, focus on what pleases you, If you want 19s have them
