I need to remove the fuel tank from my 1978 924. The chilton manual tells me to remove the transmission first. Is this mandatory, or is there a trick.
Thanks Steve
Thanks Steve
You have to take out the diff on a 944, and I think the tank part numbers are the same in both cars. Before I do that I've patched a leak with 'Petro patch' (got it off Ebay). Might have worked... I'll tell you in another few days. The leak was under the strap offside corner.
