I should be installing the roll bar by myself and I´ll need to remove front seats, any instructions ?
Thanks in advance! :cheers:
Conrado
Removing the seat is pretty easy.
1) Make sure the key is not in the ignition
2) Remove the black plastic covers on the end of the seat rails.
3) Use a reverse torx head socket to remove the 4 bolts in the seat rail (you'll have to move the seat back and forth to get to all of them)
4) Tilt the seat back so you can see underneath. Undo the electrical harness connector.
5) Place some towels or something to protect the rear console and the door sill
6) Remove the seat
7) Repeat for the other side
8) Do not put the key back in the ignition until the seats are reinstalled and the electrical connections made, or you will trigger the air bag light.
Hope this helps.
Karl
