Oh, it's not possible. It's real. And I called PCNA this morning at 0705 CST. The call center rep was very nice, but had no information about either recall (wiring harness in engine bay or transfer case) yet! Their suggestion was for me to contact my dealer.
Toby
Dated Feburary 16, 2004
Make:    PORSCHE
Model:  CAYENNE S, TURBO
Year:  2003, 2004
Recall Number:  04V069000
Summary:
ON CERTAIN SPORT UTILITY VEHICLES, THE MAIN WIRING HARNESS WAS INCORRECTLY ROUTED. DAMAGE TO THE MAIN WIRING HARNESS CAN LEAD TO THE FAILURE OF VARIOUS ELECTRICAL SYSTEMS.
Consequence:
IN EXTREME CASES, TO A CABLE FIRE BENEATH THE INSTRUMENT PANEL IN THE PASSENGER COMPARTMENT.
Remedy:
DEALERS WILL RE-ROUTE THE WIRING HARNESS. THE MANUFACTURER HAS NOT YET PROVIDED AN OWNER NOTIFICATION SCHEDULE FOR THIS CAMPAIGN. OWNERS SHOULD CONTACT PORSCHE AT 1-800-545-8039.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
And the second one (MY2004 only)...
Dated February 16, 2004
Make:    PORSCHE
Model:  CAYENNE, S, TURBO
Year:  2004
Recall Number:  04V071000
Summary:
CERTAIN SPORT UTILITY VEHICLES MAY HAVE HAD A TRANSFER CASE INSTALLED THAT COULD, DUE TO CHANGES IN THE HOUSING CASTING, RESULT IN THE OIL PUMP ROTATION. SHOULD THIS OCCUR, OIL STARVATION OF THE INTERNAL GEARS MIGHT RESULT.
Consequence:
CONTINUED OPERATION OF THE VEHICLE COULD RESULT IN A FRACTURE OF THE TRANSFER CASE HOUSING. INCORRECT TORQUE WOULD THEN BE APPLIED TO THE DRIVEN WHEELS OR OIL COULD LEAK AND CONTACT THE TIRES.
Remedy:
DEALERS WILL INSPECT THE TRANSFER CASE HOUSING AND, IF NECESSARY, REPLACE THE TRANSFER CASE. THE MANUFACTURER HAS NOT YET PROVIDED AN OWNER NOTIFICATION SCHEDULE FOR THIS CAMPAIGN. OWNERS SHOULD CONTACT PORSCHE AT 1-800-545-8039.
Notes:
And a third one for MY2003 only...
Make:    PORSCHE
Year:  2003
Recall Number:  04V068000
Summary:
ON CERTAIN SPORT UTILITY VEHICLES, IF THE GROUND CONNECTION BETWEEN THE SPIRAL RING OF THE TANK FILLER NECK AND THE CONNECTING PIPE TO THE FUEL TANK IS INADEQUATE, THE FLOW OF FUEL DURING REFUELING CAN CREATE AN ELECTROSTATIC CHARGE, WHICH COULD DISCHARGE AND SPARK. THIS SPARK COULD IGNITE FUEL VAPORS IN THE AREA OUTSIDE THE TANK FILLER NECK THAT COULD LEAD TO A MUFFLED DETONATION.
Consequence:
DUE TO SUCH A STARTLING EVENT, THE INDIVIDUAL REFUELING THE VEHICLE COULD REMOVE THE FUEL NOZZLE AT PRECISELY THE MOMENT OF THE DETONATION WITHOUT FIRST STOPPING THE FUELING PROCESS. IN SUCH A CIRCUMSTANCE, FUEL ESCAPING OUTSIDE OF THE FUEL TANK MAY IGNITE, RESULTING IN A FIRE.
Remedy:
DEALERS WILL INSPECT THE GROUND CONNECTION AND, IF NECESSARY, CORRECTED. THE MANUFACTURER HAS NOT YET PROVIDED AN OWNER NOTIFICATION SCHEDULE FOR THIS CAMPAIGN. OWNERS SHOULD CONTACT PORSCHE AT 1-800-545-8039.
Notes:
