I just changed out both rear brakes pads and rotors on my car. Anybody know the proper way of breaking them in? The parts are stock Porsche parts.
TIA!
:unsure:
TIA!
:unsure:
Take the car out and get to an area where you can accelerate and brake repeatedly. Get the car up to 50 or so and then evenly apply the brakes until almost stopped. DO NOT keep you foot on the brake pedal when you are stopped (unless you HAVE to). Repeat several times, inceasing the pressure you apply to the brake pedal. A couple of hard braking applications will complete the break in. Now enjoy the car.
You can also drive the car while applying the brakes lightly while driving. Keep doing this for several miles increasing the pressure to the pedal. The idea is to get the brakes hot and seated without letting the pads sit still against the rotor. No further break in is necessary.
Edited by 1999Porsche911
Did you use "brake clean" on the rotors before mounting? Get any oils out. I didn't, it was very "entertaining", but I wouldn't recommend it.
