Symptom #1
My MY03 996 cabriolet has been leaking a very small amount of coolant (I think) from the cap even though it is the newer part. I haven't had a chance to clean it properly and make sure it "clicks" when closed. Today, I opened the cap to clean it and noticed pressure being released. Not too much, but noticeable.
Symptom #2
During the past 2 months the on-board computer has reported an Oil Pressure Sensor Failure twice. The error went away both times after I switched the car off and on so I didn't pay too much attention. Today, whilst driving I noticed that the oil pressure during acceleration was at "5" and during idle at 3.5. It seemed as if pressure was higher than normal. Then, after accelerating hard (maybe relevant?) I noticed the oil pressure was back to normal, with idle pressure at 2-2.1 and 4.5 whilst accelerating.
The two symptoms got me a little bit worried. Am I being paranoid?
Is symptom #1 normal for the 996? Can you think of any other reason why the coolant system would maintain higher pressure even when cold?
There should be very little pressure released when the car is cold. The pressure will vary as to how the car has sat without being run.
A leak is not normal.
Thank you Loren for your reply :D . If this is the case then I guess I can replace the oil pressure sensor (since it is inexpensive) and make sure the coolant tank cap closes properly and re-evaluate the symptoms. The leak I was referring to is absolutely minimal (go from a-little-below-max to min in two months) and I am almost certain it is from the cap.
Edited by mpikounis
